RiPe_3968971
First reply posted First question asked First like given
Hello.
Softune FR Family IDE/Compiler: Is there any possibility to save compiler messages (Errors, Warnings, ...) in one file and use it in another tool?
Thank you!
You can create make file to call the compiler/linker in command line mode and now you can save all messages with forwarding of stout to a file.
Example: fcc911s.exe -V > c:\log.txt
Amy Wang
HongyanW_86
100 solutions authored 100 replies posted 50 solutions authored
Please try to right click in the build message output window and select Logging>>Start. Then build your project and all messages will be save in one log file. Please check if this meet your requirement.
Amy Wang
Thank you very much for your answer.
Probably was my email to short. I like to generate "listing file" outside of IDE (probably I may call Compiler from one batch file)... Then we may parse this file for messages...
Petar Ristanovic
Amy Wang
