SK-FM4-216-ETHERNET can't use some GPIO's
GeGa_1196981
I'm now able to manipulate GPIO using this statements:
Gpio1pin_InitIn(GPIO1PIN_PA4, Gpio1pin_InitPullup(1u));
Gpio1pin_Put(GPIO1PIN_PA6, 1);
but it only works with a few ports, when I try this:
Gpio1pin_InitIn(GPIO1PIN_P50, Gpio1pin_InitPullup(1u));
it gives me this warning and error:
..\source\main.c(299): warning: #223-D: function "GPIO1PIN_P50_INITIN" declared implicitly
.\output\release\s6e2ccxh_template.axf: Error: L6218E: Undefined symbol GPIO1PIN_P50_INITIN (referred from main.o).
what I'm doing wrong? is there any other way manipulate ports?
Roy_Liu
First comment on KBA 10 questions asked First comment on blog
Looking at the warning and error message looks like s6e2ccxh does not have P50, while s6e2ccxl( the device assembled on the SK-FM4-216-ETHERNET board) has P50.
Roy Liu
Roy_Liu
Roy Liu
GeGa_1196981
Yes, that was my problem, I was using a different template, I could program the device anyway so I was misleading by that, thank you, it works well now.
