I just started using SK-FM4-216-ETHERNET Evaluation Board and it comes with a few examples but I'm looking for the most basic, to understand the use of inputs and outputs, press a button and turn an LED things like that.
Is there any sample code that explain the use of GPIO's?
The software I'm using is Keil uVision 5
Hi GeGa,
Please you can download and install the PDL v2.1, you will find the basic sample code in the installation path and refer to its quick start guide for how to run the code.
The PDL https://www.infineon.com/cms/en/design-support/software/software-archive/peripheral-driver-library-p... DOWNLOAD - PDLSetup_2.1.0_3-26-18.exe
The quick start guide(also attached with this reply)- https://www.infineon.com/dgdl/Infineon-Peripheral_Driver_Library_v2.1_Quick_Start_Guide-Software-v03...
Hi GeGa,
I'm trying to use this PDL Version but it looks like is for a different part number, can this be used for all the FM4 family?
Yes, it can be used for all the FM4 family.
