MillYin
First question asked Welcome!
Can we use SAF-C161PI-LF CA to replace SAF-C161PI-LF 3V CA directly? What's the difference between these two products? Is the difference only working voltage?
Roy_Liu
First comment on KBA 10 questions asked First comment on blog
Looks can do this replacement, for difference, you may need to read the datasheet here, which is for both.
Roy Liu
Roy_Liu
Roy Liu
