Legacy microcontrollers Forum Discussions
user_3764331
First reply posted First question asked First like given
Greetings...
I am using the Traveo S6J337CJ microcontroller. In CAN the data is getting pushed out to the CAN transceiver IC.
It stays the while loop "while ( 0 != (pstcCanFD->unTXBRP.u32Register & 0x00000001 )) /* Check the TRP0 */"
Can anyone help me to solve this issue.
I am using the standard libraries which is provided by the supplier. "canfd.c" ,  "canfd.h" , "canfd_generated.c"
Not coming out of this while loop
    /* Check whether Tx buffer is empty or not */
        if(pstcCanFD->unCCCR.stcField.u1INIT == 1)
            return ErrorOperationInProgress ;
My pin configurations:
    /* PORT - port pin configuration */
    stc_port_pin_config_t stc_port_pin_config331 = {
                                                     .enOutputFunction      = PortOutputResourceF,
                                                     .enOutputDrive         = PortOutputDriveA,
                                                     .enPullResistor        = PortPullResistorNone,
                                                     .enInputLevel          = PortInputLevelCmosA,
                                                     .bInputEnable          = FALSE,
                                                     .bNoiseFilterEnable    = TRUE,
                                                     .enGpioDirection       = PortGpioOutput,
                                                     .enGpioInitOutputLevel = PortGpioHigh
    Port_SetPinConfig( 3, 31, &stc_port_pin_config331 );
    stc_port_pin_config_t stc_port_pin_config330 = { .enOutputFunction      = PortOutputResourceGPIO,
                                                 .bInputEnable          = TRUE,
                                                 .bNoiseFilterEnable    = FALSE,
                                                 .enGpioDirection       = PortGpioInput,
                                                 .enGpioInitOutputLevel = PortGpioLow};
    Port_SetPinConfig( 3, 30, &stc_port_pin_config330 );
HongyanW_86
100 solutions authored 100 replies posted 50 solutions authored
For input pin, you also need to configure RIC_RESIN register to select the right port input. Please kindly work with local Cypress FAE to debug your issue.
Amy Wang
HongyanW_86
Amy Wang
