TsSh_4608526
First reply posted First question asked
Hi everyone:
I am using S6E2CC as a development kit, I am wondering to use SEGGER Embedded Studio as my IDE, thus I need to use Flash USB Direct Programmer to get the J-link firmware into the Cypress on-board debug solution.
I already download SK-176-s6e2ccTestCode-V12.srec file and try it on Flash USB Direct Programmer. However, there is an error for downloading 'ERROR MCU:9EH No.001 Download error'. I am thinking about since the user manual guide said"connect a USB cable between CN3 and PC.", but I am connecting CN2. However, the problem is the board is not working when I connecting CN2(no power, no LED). Is it normal?? Or there is something wrong with my board? I appreciate with your suggestion, thanks!!
best regards,
Shen
Amy_Qian
5 sign-ins 10 solutions authored 10 replies posted
Connect the USB cable to CN2 to power the board. The green power LED3 will illuminate. If it does not, please ensure that jumper J4 is in 1-2 position.
and when you use FLASH USB DIRECT Programmer, please ensure the correct COM port.
please refer the following start guide document.
https://www.cypress.com/documentation/development-kitsboards/sk-fm4-176l-s6e2cc-quick-start-guide
Amy_Qian
