We are using S6E1A of FM0+ series.
For IO with general-purpose IO (GPIO) and timer input (TIOB) functions,
We are considering using these modes while switching them dynamically.
So please tell us about the following.
When changing GPIO to TIOB, Do you know how long it can be used as a TIOB?
When changing TIOB to GPIO, Do you know how long it can be used as a GPIO?
Are these switching times specs?
We are sorry for late response...
Could you please let me ask you gain to clarify how you GPIO? (Input or Output)
If you use GPIO as Input, you don't need to switch from TIOB to GPIO. You can read GPIO, even though TIOB is configured.
https://www.cypress.com/file/223031/download
Refer to the Figure 2-1 Block Diagram of the I/O Port in CHAPTER 10-1: I/O Port, 2.1 Configuration of the I/O Port.
While, if you use GPIO as Output, there shall not timing constrain. External device should be configured for I/O configuration, and it take some time.
Then, you can change from TIOB to GPIO.
At last, there is no spec for the switching time between TIOB and GPIO, due to SW configuration exists.
Please clarify what you would like to know.
Do you want to know time consuming to switch functionality between GPIO and TIOB?
regards,
Takashi-san,
That's right.
We would like to know time consuming to switch functionality between GPIO and TIOB.
Is there any other way to actually measure using other GPIOs?
We use GPIO as input.
We understood that the port can be read without switching the GPIO input to TIOB.
Thank you for your support.
