Sathiya
First question asked First like given Welcome!
We have a popular legacy product which uses the CY7C53150 Neuron chip.
The issue we are facing is, the recommended EEPROM part "Atmel AT29C512" got obsolete and we could not find any stock. We need to find the replacement memory chip urgently.
Or is there any configuration setting available on the Neuron chip side (Node Builder) which we can alter so that, the 3150 Neuron chip will work with other available EEPROMs? We need your technical expert advice on this.
Similar issue has been already discussed in the below thread, but I couldn't find any solution:
https://community.infineon.com/t5/Other-Technologies-General/CY7C53150-external-flash-memory/m-p/275...
I hope you can help us in resolving the issue on urgent basis.
Thanks in advance.
