Legacy microcontrollers Forum Discussions
How can I read and program a chip with the DAP miniWiggler?
Hi Andre,
First, you need to install DAS Server.
Then you should be able to use mini wiggler with tools like Keil, Memtool or DAVE.
I have already installed DAS server, what should I do next?,
and why it needs 2 different programs to program and read a chip?
Hi Andre,
DAS server is the host program and the debugger software are the client.
It is like a driver for the miniwiggler.
So now you just need to select DAS/UDAS from your debugger program as the communication interface.
