I am using Fujitsu Microcontroller MB9A314L.
I am interfacing Motor Rotary Encoder to read the motor rpm for the same I am trying to use the QPRC module available in microcontroller using PDL library API. I am using example code available in Cypress -> FM_PDL_2.0.1 (Library). I am using Vision Keil 5 IDE, Program build successfully without any error but I not getting any output related to QPRC module. No Intterup generated. I am also trying by reading the Position counter register and Revolution counter register but both registers shown '0' output. Also checked the PIN assignment, but PIN assignment is also kept/connected as mentioned in example(README file).
Kindly Help to solve above issue.
Thanks in advance.
Thanks for the replay,
I got the issue, my pin mapping use in software/program is wrong.
I have corrected that and now it's working.
Also,
As suggested I have download PDL 2.0.2.
Did you try debugging the code if you have debugger? And try the code available in PDL 2..0.2 FM PDL 2.0.2 Complete Setup
Also,
