07:24 AM
Mar 08, 2016
07:24 AM
HI,
I want to use the PWM (PWMSP001 ) on XMC1100 but when I try to generate the code it's says "Fail to update one or more resources".
I tried to update all XMC1100 files as you mention on this forum for this type of error but no succes.
I seen there was another post where the same problem was mentioned.
I have to stick with DAVE3.
Is there any solution?
Thank you.
LE: Please move this to XMC topic. Sorry
Thank you.
