can any one provide the example  software for sector erase suspend command?
my requirement is to Erase a half of the sector and remaining data should not effect by using erase operation.
for example: I want to erase sector SA2 from 0x2000 to 0x4000 only.
But when am using the sector erase command the total sector is erased.
So any one help me for the same.
Anil
ChaoHaiM_11
25 replies posted 10 sign-ins 5 sign-ins
Hi Anil,
Sorry, we have not the flash operation example project of MB95F718.
I enclose code snippets from other series for your reference.
  .SECTION ERASECODE, CODE
  .EXPORT _EraseStart
; Command_Process
;  Flash Erase
; IN : EP : Erase Address
; OUT : A  : Return Flag
; 0 : Successed
; 1 : Fail
_EraseStart:
MOVW A,EP
PUSHW A ; Save write address
SETB 72H:1 //FSR:WRE
MOVW A,#0xF000
ANDW A
MOVW A,#0x0AAA
ORW A
MOVW EP,A ; 0x0AAA | (address & 0xf000)
XCHW A,T
MOVW A,#0x0554
ORW A
MOVW IX,A ; 0x0554 | (address & 0xf000)
MOV A,#0xAA ; 0x*AAAH <= 0xAA
MOV @EP,A
MOV A,#0x55 ; 0x*554 <= 0x55
MOV @IX,A
MOV A,#0x80 ; 0x*AAAH <= 0x80
MOV @EP,A
MOV @EP,A
MOV @IX,A
POPW A ; Restore Erase address
MOVW EP,A
MOV A,#30H ; The last data.
mov @EP,A ; Start Erase
NOP
NOP
// clear watchdog
MOV 0CH, #0x35
EraseDQ3:
MOV A,@EP
AND A,#0x08 ; Check DQ3 ?
BZ EraseDQ3
EraseLoop:
BBS 72H:4,EraseEnd //FSR:RDY
// clear watchdog
MOV 0CH, #0x35
MOV A,@EP
AND A,#0x20 ; Check DQ5?
BZ EraseLoop
BBS 72H:4, EraseEnd //FSR:RDY
NOP
EraseError:
MOV A,#0xF0
MOV 0xFF00,A ; Reset Flash
MOV A,#01H ; Set error Flag
CLRB 72H:2
RET
EraseEnd:
CLRB 72H:2
MOV A, #0X00
RET
/*Module name:   Flash_Erase        */
/*Function description: flash erasing operation                                              */
/*Return: 1--OK        */
/*        0--NG        */
unsigned char Flash_Erase(unsigned int Address, unsigned char Sector_Chip)
unsigned char temp;
address = Address;
SWRE0 = 0x3F;
WDTC = 0x35;// clear watchdog
#pragma asm
MOVW A, _address // set erase address
MOVW EP,A
CALL _EraseStart // Start erase subroutine
MOV _result,A // Reture the result for flash erase
POPW IX
#pragma endasm
return result;
ChaoHaiM_11
Hi Anil,
  .EXPORT _EraseStart
; Command_Process
;  Flash Erase
; 0 : Successed
; 1 : Fail
_EraseStart:
MOVW A,EP
MOVW A,#0xF000
ANDW A
MOVW A,#0x0AAA
ORW A
XCHW A,T
MOVW A,#0x0554
ORW A
MOV @EP,A
MOV @IX,A
MOV @EP,A
MOV @EP,A
MOV @IX,A
MOVW EP,A
NOP
NOP
// clear watchdog
MOV 0CH, #0x35
EraseDQ3:
MOV A,@EP
BZ EraseDQ3
EraseLoop:
// clear watchdog
MOV 0CH, #0x35
MOV A,@EP
BZ EraseLoop
NOP
EraseError:
MOV A,#0xF0
CLRB 72H:2
RET
EraseEnd:
CLRB 72H:2
MOV A, #0X00
RET
/*Return: 1--OK        */
/*        0--NG        */
unsigned char temp;
address = Address;
SWRE0 = 0x3F;
#pragma asm
MOVW EP,A
POPW IX
#pragma endasm
return result;
