unmirsad
I want information about Fujitsu micro controller MB90F497G, (how is possible reprogramming and which interface I need to used). I have 3 node with same micro controller but I need reprogramming 2 other Copy-past.  I also wan t know if have some interface for programming direct in board without take out micro controller.
Mirsad
ShipingW_81
Sorry for late reply.
We propose to use the serial Flash programming mode with 16LX Flash MCU programmer.
The MD2, MD1, MD0 pins, and Pxx pins cannot be controlled by the PC and should be set in the user system. During serial programming, set the HSTX pin to High (only for microcontrollers with the HSTX pin).
When the RSTX pin is set from Low to High level after setting the MD2, MD1, MD0 pins, and Pxx pins, the microcontroller enters the serial reprogramming mode, enabling serial reprogramming from the PC.
The port numbers and settings of the set P00/P01 pins and the port numbers of the SIN1 and SOT1 pins vary with the types of microcontrollers.
Please install the Programming tool.
Unfortunately, I have no serial programming specification available for the MB90F497G.
You need the MODE pins for configuration of serial communication mode and the GPIO pins P00/P01 for selection of async and synch UART.
Please find attached Flash programming tool and rename the encrypted file to zip
Password: cypress
Fred
ShipingW_81
Maybe you can get the FLASH MCU Programmer for F2MC-16LX from link - http://www.cypress.com/documentation/software-and-drivers/flash-mcu-programmer-1?source=search&keywo...
The programming interface is uart - RS232C(through USB hub or USB-RS232C cable).
unmirsad
Ok i m relative new with this, that way i want know more information. i want know how i can read one and programming another same microcontroller. i want programing this microcontroler direct in matchboard. in matchboard have plug pin for programming SOT, SIN, MD0, MD1, MD2, RST, +5v and minus pole. i m try read with normaly TTL but can t read. I m confused abouth MD0,MD1,MD2 pin. In description om programming microcontroller have also start pin for programming P00,P01, but in pinout conector don t have this 2 pin.
ShipingW_81
Seems still not clear enough for your issue. you have made the custom matchboard? what's the 'pinout conector' you mentioned refer to?
maybe a draft scheme or pic is helpful to get full understanding of your use case.
unmirsad
unmirsad
i m make interface like this schema, but when i conect device i can t read. I need read this mcu and programm to another. i m conect pin SOT, SIN, MD0, MD1, MD2, Vcc, and Vcs, but i m litlle confused abouh this 8 dip switch near MCU. olso i don t know abouth pin P00, P01.
ShipingW_81
Password: cypress
Fred
