I have done something out of error to lock up my start kit xc2000 board which specifically is the xc2787. I normally am able to debug with keil and flash with memtool but if I try to connect to the board via the USB keil says the board is locked and memtool just says it can not connect to the board. Is there a way to factory reset the board or somehow re-flash it? Any help is appreciated. Thanks!
Okay the solution was set one of the DIP pins and then use memtool with a password to connect, from there I was able to un hardware protect and reflash. hope this helps someone...
