I want total of 9 chs of 32-bit counters. PSoC4 cannot be implemented because TCPWM is 16bit. PSoC 6 cannot be used because I want to use 5V interface.
Can it be implemented in the FMx series? If it is yes, what is the configuration?
Also, can I count both edges of the clock?
Tetsuo
Legacy Microcontrollers
As I said, FM series can support 32-bit counter (using 2ch) and both edge.
However, the problem is that FM series support maximum 8ch of 32-bit counter.
regards
Have you checked e.g. 32-Bit Microcontroller FM3 Family Peripheral Manual Timer Part?
Even if we have to check your requirements more, FM3 has 32bit operation mode.
Takashi-san,
Thank you for your answer.
I saw the peripheral manual. However, there is no description as to whether dual edge counter operation is possible. Is it possible?
Tetsuo
regards
