HI, I'm trying to write (program) the workflash in the chip MB9DF566. The code is as follows:
IDE: IAR for ARM
#define WFCFG_UNLOCK_CODE 0xCF6DF1A5
#define WFCFG00_MA1_BASE (0x0E000000) // Base Addr of the workflash
#define WFCFG00_UNLOCK \
WFCFG00_CPR = WFCFG_UNLOCK_CODE; \
void Init_WorkFlash00(void)
// Program enable
//WFCFG00_UNLOCK;
//WFCFG00_CR_WE = 1;
// Flash wait control
WFCFG00_UNLOCK;
WFCFG00_CR_FAWC = 2;
// Enable ECC
WFCFG00_UNLOCK;
WFCFG00_ECR_ECCOFF = 0;
// Disable DMA
WFCFG00_WCR_DMAEN = 0;
// Disable the generation of hang interrupt requests
WFCFG00_ICR_HANGIE = 0;
// Disable generation of ready interrupt requests
WFCFG00_ICR_RDYIE = 0;
// Clear interrupts
WFCFG00_ICR_HANGIC = 1;
WFCFG00_ICR_RDYIC = 1;
// Software reset
WFCFG00_UNLOCK;
WFCFG00_CR_SWFRST = 1;
void WorkFlash00Write(uint32_t Addr_Offset, uint32_t Data)
uint32_t *pDes = ((uint32_t *)WFCFG00_MA1_BASE) + Addr_Offset;
// Program enable
WFCFG00_UNLOCK;
WFCFG00_CR_WE = 1;
while(0 != WFCFG00_WSR_ST);
*pDes = Data;
while(1 != WFCFG00_SR_RDY);
// Program disable
WFCFG00_UNLOCK;
WFCFG00_CR_WE = 0;
When the code steps over the line:
*pDes = Data;
the regester WFCFG00_BERR_ACCIGN = 1, which means a command overrun, and the write operation fails.
Then when steps over the next line, the IAR show me a dialog "Warning: Stopped at unknown breakpoint".
Please help me to find the right way to write the workflash. Maybe directly access the workflash by point is not right, but I couldn't find a register which could access the workfalsh area.
Other Legacy MCU
For your concerned issue, please kindly contact your local Cypress Sales or Cypress distributors to get technical support.
Amy Wang
The problem still bothers me.
Amy Wang
