How to write the work flash ? (CHIP model: MB9DF566)
HI, I'm trying to write (program) the workflash in the chip MB9DF566. The code is as follows:
IDE: IAR for ARM
#define WFCFG_UNLOCK_CODE      0xCF6DF1A5
#define WFCFG00_MA1_BASE           (0x0E000000)     // Base Addr of the workflash
#define WFCFG00_UNLOCK                                             \
          WFCFG00_CPR = WFCFG_UNLOCK_CODE;        \
void Init_WorkFlash00(void)
          // Program enable
          //WFCFG00_UNLOCK;
          //WFCFG00_CR_WE = 1;
          // Flash wait control
          WFCFG00_UNLOCK;
          WFCFG00_CR_FAWC = 2;
          // Enable ECC
          WFCFG00_UNLOCK;
          WFCFG00_ECR_ECCOFF = 0;
          // Disable DMA
          WFCFG00_WCR_DMAEN = 0;
          // Disable the generation of hang interrupt requests
          WFCFG00_ICR_HANGIE = 0;
          // Disable generation of ready interrupt requests
          WFCFG00_ICR_RDYIE = 0;
          // Clear interrupts
          WFCFG00_ICR_HANGIC = 1;
          WFCFG00_ICR_RDYIC = 1;
          // Software reset
          WFCFG00_UNLOCK;
          WFCFG00_CR_SWFRST = 1;
void WorkFlash00Write(uint32_t Addr_Offset, uint32_t Data)
          uint32_t *pDes = ((uint32_t *)WFCFG00_MA1_BASE) + Addr_Offset;
          // Program enable
          WFCFG00_UNLOCK;
          WFCFG00_CR_WE = 1;
          while(0 != WFCFG00_WSR_ST);
          *pDes = Data;
          while(1 != WFCFG00_SR_RDY);
          // Program disable
          WFCFG00_UNLOCK;
          WFCFG00_CR_WE = 0;
When the code steps over the line:
*pDes = Data;
the regester WFCFG00_BERR_ACCIGN  = 1, which means a command overrun, and the write operation fails.
Then when steps over the next line, the IAR show me a dialog "Warning: Stopped at unknown breakpoint".
Please help me to find the right way to write the workflash. Maybe directly access the workflash by point is not right, but I couldn't find a register which could access the workfalsh area.
For your concerned issue, please kindly contact your local Cypress Sales or Cypress distributors to get technical support.
Amy Wang
HongyanW_86
100 solutions authored 100 replies posted 50 solutions authored
nofl​ Do you have any suggestion about this MB9DF566 workflash write issue?
Amy Wang
The problem still bothers me.
Amy Wang
