My question relates to XC2300 family MultiCan module.
See user manual ref xc2300e_um_v1.0_2011_01.pdf
My question is : how much lists are currently supported by the multican module ?
The xc2300e_um_v1.0_2011_01 manual is definitely unclear about that :
- Page 22.4, n_lists is clearly specified to 8
- Page 22.14, it is said that "The MultiCAN module provides 16 different lists" and also there is a "A 4 bit LIST bit field in the Message Object Control Register", (so assuming there are 16 lists)
- Page 22.58 that chapter rawly says there are only 8 lists, and this looks confirmed by the number of available LISTxH registers.
- Page 22-85, LIST field is effectively codded with 4 bits, meaning 16 lists could be supported.
So, what's the effective number of supported lists?
Vincent
