User22663
Hi there. I'm wondering to write a flash file on microcontroller SAK-XC2288H-200F100L.
I have a repair automotive center and when I was using a tool to reflash the microcontroller an ECU that uses this microcontroller, the power supply suddenly stopped working.
As AutoVEI couldn't repair, I thought I could rewrite the flash using some universal programming or some other tool because I have the binary and .hex of the flash file.
Which tools do you advise me to reflash it? I don't need to debug, just write and read flash (1600kb)
I have Segger JLink and FTDI with me, but I believe none of them can be used to flash this microcontroller, right?
Ps.: In my research, I've found some tools to do this job like Beeprog, Miniwiggler, and some others but I'm worried about spending money and not being able to reprogram because of having some kind of flash lock. Is it possible for this to happen?
User22695
Hi. Keil ulink2 can work with xc2288h.
User22663
Thank you. I'll check this out
