I'd like to do more fine grained interrupt masking, such as only setting EADC = 0 while reading from the variable my ISR stores the conversion result in.
EADC = 0;
adc7_copy = adc7;
EADC = 1;
My question is, will an interrupt be lost while EADC is disabled or will it be serviced once EADC is enabled again?
So far I've done all that masking with EA. But I'd prefer to make such locks not only as short, but also as narrow scoped as possible.
I've done some reading and now I think I'll get the desired result if I set IMODE = 1.
Yes, IMODE=1 is exactly what you need in this case
Thank you for the confirmation!
