shma_1538871
Level 4
Level 4
25 replies posted 25 sign-ins 10 replies posted
Hi All
I have a question about baud rate calculation of FM4.
Peripheral manual mentions sampling timing margin.
Margin of minimum data rate is 1 clock.
Margin of maximum data rate is 2 clock.
I'd like to know the reason why margin is not same.
Please tell me the detail of 1 clock and 2 clock margin.
Matsushita
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Hello Matsushita-San,
One or two bus clock cycles in the fomula of FLmin/FLmax are additional bus clock cycles required by MFS circuit to sample the inputs.
The theoretical FLmin and FLmax formula is,
FLmin=(11bits * (V+1) – (V+1)/2 + 1)/φ
FLmax=(21/20 * 11 * (V+1))/φ
However, practically MFS requires one or two additional bus clock cycles to sample the inputs.  Thus, practical formula for FLmin and FLmax is;
With the sampling timing margin of one bus clock (φ), FLmin = (11bits × (V+1) - (V+1)/2 + 2)/φ
With the sampling timing margin (φ) of two bus clocks (φ), FLmax=(21/20 * 11 * (V+1) - 44/20)/φ
Geona Mary
GeonaP_26
Geona Mary
