C_T_T
First question asked Welcome!
I would like to create a serial writer to write to the built-in flash memory of the FM4 and FM0+ series.
The manual posted on HP does not seem to include the command protocol when using serial writer mode.
Is it possible to obtain this information for the FM4/FM0+ series?
Is it also uploaded to the HP?
Takashi_M
1000 replies posted 500 solutions authored 750 replies posted
Hello C_T_T,
We introduce the programming specs for FM0/3/4 series as MotooTanaka san mentioned above on our home page.
if you need further information on this, it would be suggested that you contact to IFX sales representative.
regards
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I googled some, and the following URLs might be some hints for you.
FM4 Family S6E2G Series Flash Programming Specifications
https://www.infineon.com/dgdl/Infineon-FM4_Family_S6E2G_Series_Flash_Programming_Specifications-Prog...
FM0+ Family S6E1A1 Series, Flash Programming Specification
https://www.infineon.com/dgdl/Infineon-FM0+_Family_S6E1A1_Series_Flash_Programming_Specifications-Us...
FM3 32-BIT Microcontroller MB9BF500 Series FLASH PROGRAMMING MANUAL
https://www.fujitsu.com/tw/Images/CM91-10102-2E-20100415a.pdf
FM3, MB9A310/110 Sereis Flash Programming Guide I
https://www.infineon.com/dgdl/Infineon-CY9A310-1-MN706-00007-1v0-E-Programming%20Specifications-v02_...
moto
Takashi_M
Hello C_T_T,
regards
