Dear Cypress fans,
I have a problem with the Keil uVision5, PDL 2.1.0 and the FM4-176L-S6E2CC-ETH kit.
When I use the project template I get the warning see "UV4_208-03-12_15-32-36.png" => project added startpoint.zip
I tried another option:
When I use Keil Runtime environment for the configuration of my project with "CMSIS Core" and "Device Startup", my device is set to Cypress FM4 "S6E2CCAJ0A"
     I get the error: RTE\Device\S6E2CCAJ0A\system_s6e2cc.c(216): error:  #20: identifier "FM4_LCR" is undefined => project problem_uvision_runtime.zip
Can someone help me out?
Kind regards
Vincent
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Hello Vincent,
Functions used in gpio.h internally uses GPIO registers and bitband section defined in s6e2ccxj.h. You can resolve Implicit Declaration warning of GPIO functions by including s6e2ccxj.h in main.c.
Could you share the screen shot of the second error?
Geona Mary
