FLASH Tool for TRAVEO Cypress S6J336CJ controller
user_3764331
First reply posted First question asked First like given
Greetings,
Can anyone suggest a flashing(hex flashing) tool for (S6J336CJ) this specified controller.
HongyanW_86
100 solutions authored 100 replies posted 50 solutions authored
Flash Programmer for Traveo can be used to flash hex file to S6J336C via UART.
http://www.cypress.com/documentation/software-and-drivers/flash-mcu-programmer-1
For the latest version, please kindly get in touch with Cypress local sales team or distributors.
Amy
HongyanW_86
Amy
Greetings,
Thanks for your response.
I have downloaded the software which you referred. But in that software
S6J336CJ controller is not listed in the microcontroller selection check
box.
I have attached the screen shot of the flashing tool.
And we are using IAR I-jet debugger . Is there any tool to flash/erase the
S6J336CJ microcontroller vis I-jet debugger?
Please guide me to flash the hex file via UART. and flash/erase via I-jet
debugger.
Mohan kumar G
Engineer - Engineering Service Department
PRICOL CORPORATE SERVICES LIMITED
132, Ooty Main Road, PB No. 4209, Perianaickenpalayam, Coimbatore, 641020,
India
M : +91 94889 06010 | T : +91 422 433 1556 | E :
mohankumar.govindarasu@pricol.co.in
W : www.pricol.com
If you are not required to maintain a printout for legal or audit
purposes, please consider the environment before printing this email.
Privileged/Confidential Information may be contained in this message. If
you are not the addressee indicated in this message (or responsible for
delivery of the message to such person), you may not copy or deliver this
message to anyone. In such case, you should destroy this message and
kindly notify the sender by reply email. Please advise immediately if you
or your employer does not consent to email or messages of this kind.
Opinions, conclusions and other information in this message that do not
relate to the official business of the sender's company shall be
understood as neither given nor endorsed by it.
