TeMa_2997106
Level 6
Level 6
Distributor - TED (Japan)
10 likes received 10 solutions authored 250 replies posted
I would like to get errata information about S6E1A11C0A.
Is there no errata?
The data sheet here contains the following:
  Modified according to the Datasheet Errata (002-05092 Rev. **) as below
Where is this errata?
Tetsuo
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Hi Tetsuo,
Please find the attached errata. In fact, the errata is obsolete as the information provided in the errata document was reflected in the revision B of S6E1A  datasheet(002-05091), it was not in revision A.
Roy
Roy Liu
Roy_Liu
Hi Tetsuo,
Roy
Roy Liu
TeMa_2997106
Level 6
Level 6
Roy-san,
Thank you for your information.
I will check it.
Tetsuo
Roy_Liu
You are welcom Tetsuo-san, please open a new thread if needed.
Roy Liu
