Jun 22, 2022
02:09 AM
Jun 22, 2022
02:09 AM
Does FM4 SRAM support ECC?
The FM4 web says ECC support. For example, on the S6E2H page, I found the following description.
However, there is no mention of ECC in the data sheet.
Tetsuo
Labels
Legacy Microcontrollers
10:10 PM
Jun 22, 2022
10:10 PM
Jun 22, 2022
03:56 AM
Jun 22, 2022
03:56 AM
Need to double check, but S6E2H would support ECC.
Jun 22, 2022
03:59 AM
Jun 22, 2022
03:59 AM
Takashi-san,
Thank you for your confirmation.
I would like to know if ECC is supported in all SRAM areas.
Tetsuo
Jun 22, 2022
10:10 PM
Jun 22, 2022
10:10 PM
Confirmed that ECC is supported in FLASH and SRAM0 only.
Jun 23, 2022
01:09 AM
Jun 23, 2022
01:09 AM
Takashi-san,
Thank you for your support again.
I understand.
Tetsuo
