Legacy microcontrollers Forum Discussions
User20534
Hi everyone ,
I need to choose a debugger/flash programmer for controller XC161CJ and i think miniwiggler should do this , so i have below given questions :
1. will it work with memtool to flash load the software
2. to flash load the software what all files are required (e.g. .hex file ), if i purchase miniwiggler hardware debugger
3. Will it work with tasking EDE ver (C166/ST10v8.0.r1) for debugging purpose (will it take the symbol file ? from IDE?)
4. How to connect miniwiggler to 16 pin connector.
5. Will miniwiggler able to access and flash the memory area on different chip also?
sanjyot
