01:05 AM
Dec 25, 2014
01:05 AM
I am wondering what is the difference between DAP miniWiggler V3 and DAP miniWiggler II?
Actually I have DAP miniWiggler V3 hardware and Tasking v.8.7 r1 which release notes say that it works with DAP miniWiggler II exactly.
Do you think my Tasking EDE will work with DAP miniWiggler V3?...
06:12 PM
Dec 30, 2014
06:12 PM
Hi elusive,
I believe the different is the communication interface.
In DAP miniwigger V2, there is OCDS connector where in V3, OCDS connector is no longer available and had changed it to 20-pin Automotive JTAG connector.
In term of software compatibility, I believe it is still the same as both are using the DAS server software.
Therefore, as long as the EDE support DAS server, DAP miniwiggler V3 should be compatible.
So, in order to use DAP miniWiggler V3, you have to make sure your target board are NOT using OCDS connector but rather 10-pin DAP connector or 20-pin Automotive JTAG connector.
