SySa_4665481
Welcome! 10 replies posted 5 replies posted
For those of you developing a tunable white LED lamp application, you can use the RGB LED Lighting Shield for your prototyping/evaluation works.
To find out how, check out our newly-released Application Note entitled "Tunable White LED Lamp Control with RGB LED Lighting Shield" at
http://www.infineon.com/cms/en/product/evaluation-boards/KIT_LED_XMC1202_AS_01/evaluation-boards/KIT...
The XMC Lib-based project is also available for download from the same link above.
