Hi
I have just update a PC from windows XP to Windows 10
I used Memtool version 1.7.9 via Labview 2015 and COMx to flash a C164 device.
This old version of Memtool is not working on Windows10 so I got a newer version 4.09.
But with this version I can't find the COMx when I serch for in labview!
Is it not possible to use COMx on Memtool anymore or ?
Thanks in advance
Bjarne Joergensen
Hello @Briton ,
I suppose you are using Infineon MemTool v4.09. Kindly be advised that Infineon Memtool should be used only for evaluation purposes, not productive use cases. I request you to kindly get in touch with PLS through e-mail support@pls-mc.com.
Sampath Selvaraj
Hello @Briton ,
Sampath Selvaraj
