jt_4601621
First question asked
I purchased the FM4 pioneer kit and am attempting to follow the instructions detailed in page two of this document. I have installed everything and connected to the board in the serial port viewer tool. According to the instructions, I should be presented with a list of options to test the board. The problem is that I am instead presented with a blank screen. Whenever I keydown from the serial port viewer tool, LED2 on the board flashes twice. Otherwise there is no response and nothing is displayed in the command line.
I'm using a 2015 Macbook Pro so everything is being run through VirtualBox.
This is how it looks:
Any guidance is much appreciated.
Amy_Qian
5 sign-ins 10 solutions authored 10 replies posted
please use another serial assistant terminal tools instead to test it again. such as SSCOM is recommended.
Roy_Liu
First comment on blog 1000 replies posted 500 solutions authored
Did you also referred to this document which is included in the kit webpage
Roy Liu
JoMo_4617061
First like given
Hello
I have the same problem.  Did you ever get a solution to this?
Amy_Qian
