I am using F2MC-16 Family SOFTUNE Workbench V30L32 for one of our legacy product.
Just want to know, does this version of softune workbench support command line based build for softune projects(using .wsp file).
I never tried that, but only "exported" the created MHX file.
And neither seems there any make utility in the Softune bin path.
However, what you can try:
Enable a full command line output during build, as seen here:
And then, I would try to copy/paste the compiler/assembler/linker commands into a batch file, and execute that.
