Combustion Engine CRANK Signal Decoding with XC2765X
mkiremitci
First question asked Welcome!
Hello everyone,
I would like to analyze the CRANK signal obtained from a two-stroke internal combustion engine and observe the ignition and injection signals accordingly. I have XC2765X microcontroller. I have read the processor's datasheet and I think I can perform this CRANK analysis with CAPCOM2, CCU6x, and GPT12E modules. Is there any application note or sample source code that can guide me on this issue?
I would appreciate any support you can provide in these matters.
Mert.
