CY9BF114N Data written to the Mainflash is not correct
Unic
10 sign-ins First like received First like given
        I was writing data to the main Flash using 16bit, and there was a discrepancy between the data read and the data written. I used the reference routine to simplify the code that could cause problems.
CY9BF114NPMC-G-JNE2
Unic
 Hi ChengCaiT_16,
        十分感谢您的回答,我确认过32bit的整数倍写入是没有问题的。
        我想我可能需要的不是解决方法。
        如果您有更多的了解可以加入IFX-230619-977575回复我,再次感谢。
ChengCaiT_16
First reply posted Welcome!
The flash write data size please keep 4-byte align, please try to change the TEST_SIZE as 8.
Unic
 Hi ChengCaiT_16,
        我想我可能需要的不是解决方法。
ChengCaiT_16
Don't forget  change MFlash_WriteData16Bit((uint16_t*)TEST_MAIN_SECTOR, (uint16_t*)u8TestData, 3);
to:
MFlash_WriteData16Bit((uint16_t*)TEST_MAIN_SECTOR, (uint16_t*)u8TestData, 4);
