Legacy microcontrollers Forum Discussions
jabic_2034161
First reply posted First question asked First like given
Hello
I have CY51F526 mcu. There is an crystal 4.0MHz connected.
I would like to use PLL to drive mcu with 40MHz.
How can I do it using C not assembler?
Do you have any code examples?
Jakub
HongyanW_86
100 solutions authored 100 replies posted 50 solutions authored
Here is the link of CY91520 sample code but the PLL is configured in startup.asm in assembler:
//Select tab "Sample Program"
https://www.cypress.com/products/cy91520
If you need to configure PLL in C code, please kindly refer to the start.asm and chapter 5 of CY91520.
https://www.cypress.com/file/251301/download
Amy Wang
Hello Amy
Thank you for your reply. You are right. I done something similiar.
What I did:
void PLL_INIT()
     #pragma asm
     Here I copy pased pll init rountine from asm file
     #pragma endasm
And it works perfect:)
