About transient fluctuation rate for power supply voltage
Tao_2199
Distributor - TED (Japan)
25 replies posted 50 sign-ins First like given
According to FM3(CY9BF116TBGL-GE1) datasheet on page 70, the transient fluctuation rate for power supply voltage is described following.
“the transient fluctuation rate does not exceed 0.1 V/us when there is a momentary fluctuation on switching the power supply.”
In this case, if it can’t keep this rate, how will the device be affected?
When power supply voltage is switched to 5.5V from 3V with exceed 0.1 V/us,
for example, does I/O port not work correctly(output by mistake.)?.
Tao_2199
Takashi_M
1000 replies posted 500 solutions authored 750 replies posted
Your statement described in question is for "Stabilizing power supply voltage" (like for noise).
As the datasheet mentioned, a malfunction may occurs in this case.
It is hard to specify its device behavior, and it is not guarantee.
And, when power supply voltage is switched to 5.5V from 3V with exceed 0.1 V/us, there is a possibility that   I/O port does not work correctly.
Takashi_M
