About confirmation of receive FBYTE at debugging
Tao_2199
Distributor - TED (Japan)
25 replies posted 50 sign-ins First like given
Hello.
My customer is asking about UART communication with FIFO by PDL(AN99218).
(Question)
Could you please tell me how to confirmation whether setting value of FBYTE(ex.6byte)is correct at debugging.
To confirm setting value of FBYTE, they checked(watched)it at debugging but setting value wasn’t changed. (kept to 0x00)
They think it would be shown count value that accumulated in FIFO at watch point.
(Please refer Figure 6 on Application Note:AN99218).
They understanding is correct?
If so, it can’t confirm value of FBYTE correctly with watching FBYTE at debugging.
For example, is there any problem as a way to check as following?
When some bytes of data is received and check if the receive interrupt occurs only when the intended number of bytes.
To eliminate interrupt factors except target interrupt, receive FIFO idle will be disabled(FRIIE:0).
Could you please give comment and advice for idea of FBYTE confirmation?
Tao2199
Takashi_M
1000 replies posted 500 solutions authored 750 replies posted
Tao_2199,
it seems to be this is the duplication of the following thread.
https://community.infineon.com/t5/Legacy-microcontrollers/FM4-S6E2H-%E3%81%AEUART%E3%81%AE%E5%8F%97%...
if this is correct, please refer to the above thread.
thank you.
Takashi_M
Tao_2199,
thank you.
Tao_2199
Hello TakashiM_61、
Thank you for reply.
I will refer  to the above thread.
My question will close.
Tao2199
