Dears.
Now my customer is using MB96F6B5A/R to implement HVAC.
By default, vector table is located in the address from 0xFFFC00 to 0xFFFFFF.
We are wondering that is possible to change vector table address because we want to put digital signature value in the area of 0xFFFC00 ~ 0xFFFFFF.
If yes, could you tell us how to relocate vector table address ?
Thanks and best regards,
Kevin Han.
Legacy Microcontrollers
- MB96F6B5R
I don't know the F6B variant, but deal with other 16FX controllers at the moment.
I assume all variants have a table base register (TBR) which one can set from user code. The hardware reference manual for my variant (MB96F3xx/CY963xx) says:
The area of the vector table can be changed by the user program in the table base register (TBR). It can be located either in the RAM, ROM or external area. This area is located at 1 kByte starting at the address defined by the TBR. The address of the vector table area is
VECSTART = TBR * 100H up to
VECEND = TBR * 100H + 3FFH.
The address of the vector table area is FF:FC00H to FF:FFFFH by default.
I would recommend to consult the hardware manual for details.
