Motor Control DSP Portfolio from Infenion
User22841
Hi Guys,
I am looking for a Motor Control DSP from Infineon with 32 bit FPU support.....please suggest.....I want to switch over from STM32F302 series.........
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @User22841 ,
We have motor control MCU which supports FOC for IPMSM, BLDCM and ACIM with sensor-less , Hall-Sensor  and Encoder operation.
We have XMC 4000 series which has ARM cortex M4 which supports 32-bit FPU and DSP block.
https://www.infineon.com/cms/en/product/microcontroller/32-bit-industrial-microcontroller-based-on-a...
Our iMotion controller which is a dedicated  MCU for motor control. Ready-to-use motor control eliminates software coding from the motor drive development process. IMC 100 series has only MCE which perform FOC of motor and  IMC 300 series which has a dedicated core for other application apart from MCE.
https://www.infineon.com/cms/en/product/power/motor-control-ics/digital-motor-controller-imotion/
Please watch below video for getting started with iMotion:
https://www.youtube.com/watch?v=KXDEV0p6ANM
Can you please share you type of motor , its control and application so that we can help you better in suggesting exact MCU?
Krupashankar
