Nov 18, 2021
04:08 AM
Nov 18, 2021
04:08 AM
I want to develop an SW for XE167F-96F device, but as I can c it uses the Keil c166 compiler. Can I also use GCC compiler to build the SW or can I port the SW so that it can be built using GCC compiler?
Vishal
Labels
12:12 AM
Nov 19, 2021
12:12 AM
My company uses an ECU based on a XE22xx controller, which is basically an extension of the C166.
We use Tasking VX, albeit I am not sure if that would be an improvement to Keil's toolchain, both in regard to costs and code quality.
Not sure about free gcc compilers. An equally important point is a toolchain that supports your debug pod, both for programming and debugging. The XE22xx debug interface is not JTAG, I suppose XC166 is the same.
