RAM_MARSAKATLA
Distributor
5 questions asked 10 sign-ins 5 sign-ins
Dear Team, We are working on Water purifier. We are developing UV Ballast for it. Below are the Specifications: 1. Input voltage: 24V (DC Supply) 2. Output Voltage: 90V (DC Supply) 3. Power Rating: 4W 4. Switching Frequency: 36KHz 5. Using with OSRAM Mercury Based Lamp Looking for suitable solution from Infineon.
Xiangrui
500 replies posted 250 solutions authored 50 likes received
Thanks for your interest on our products. But it's sorry to say that we haven't a perfect fit solution for your application. There are only some devices partly approach.
We have only one Ballast IC which is ICB2FL03G. However, its max. voltage Vcc is only 18V.
For other LED drivers, we have TLD5542-1 which can support 24V input voltage, but only 55V output maximum.
TLD6098-1EP supports also 24V input voltage, but a higher frequency.
Xiangrui
Xiangrui
Xiangrui
