GeGa_1196981
I been trying to replace the XDPL8105 with the XDPL8210, since the first one is out of stock, and I was wondering if this is possible?
the mayor hardware differences are 2 pins the uart port for communication and the pwm vs dimming voltaje
right now I can program the XDPL8210 on the board and I have disable the pwm function, so far so good
but the problem is the parameters are a little bit different, I have tried to set it as close as the XDPL8105, but my power supply won't turn on, just keep flashing, so what should I take in consideration to make it work, what else should I have to do different, I'll leave both files in the attachments.
Pranava_YN
XDPL8105 csv file can not be directly used with XDPL8210. Please download XDPL8210 csv file from your website. then based on excel simulation tool do the parameterization.
Pranava
Pranava_YN
Pranava
