User21095
5 sign-ins First question asked First reply posted
TLD5099EP cuK电路是否可供参考?还是演示材料?
Kumarkanahai
Moderator 5 likes given 25 solutions authored 50 replies posted
Just to add a supporting statement to my previous response, attaching the snip from the product page
As you can see from the above-attached image, TLD5099EP doesn't support Cuk Topology.
Please let us know, if you have anymore clarification required.
Kanahaiya
Kumarkanahai
Hi
Thanks for posting on the Infineon Community.
Unfortunately, TLD5099EP is not available in the Cuk topology.TLD5099EP is available in multiple topologies such as Boost, Buck, Buck-Boost, SEPIC & Flyback topology. You can use SEPIC topology for your application. SEPIC topology has less ripple and less conducted emissions compared to Cuk topology. For more details, please refer to the attached link.
https://www.infineon.com/cms/en/product/power/lighting-ics/litix-automotive-led-driver-ic/litix-powe...
Kindly let us know your application so that we can suggest the right solution suitable for you.
Kanahaiya.
User21095
Thank you for your reply. TLD5099 supports SEPIC circuit, AND I think it can support CUK. I will try CUK design with the customer.
Kumarkanahai
Kanahaiya
