Virali_Chhag
Hi Team
Greetings of the day.
I am Virali, working in Hardware Engineering Domain in Pathpartner Technologies pvt ltd Bengaluru, India.
This is to inform you  that we are working on a new Project, which involves LED driver Circuitry for Car Headlight. For LED driver Operations we have chose below IC's:
 1.TLD2131-Triple Channel High Side driver IC
 2.TLD2132-Single Channel High Side driver IC
3.TLD2141-Triple Channel High Side driver IC
I request you tell us more about Samples/Part Ordering, Part EOL, Datasheets.
Also you can suggest Higher Versions of LED Drivers for Automotive domain.
Virali Chhag
AliAsgar
Moderator 50 likes received 500 replies posted 250 replies posted
Hi Virali,
Please find following links for details on LED driver IC's chosen by you:
1. TLD2131-Triple Channel High Side driver IC - https://www.infineon.com/cms/en/product/power/lighting-ics/litix-automotive-led-driver-ic/litix-basi...
2. TLD2132-Single Channel High Side driver IC - https://www.infineon.com/cms/en/product/power/lighting-ics/litix-automotive-led-driver-ic/litix-basi...
3. TLD2141-Triple Channel High Side driver IC - https://www.infineon.com/cms/en/product/power/lighting-ics/litix-automotive-led-driver-ic/litix-basi...
We have 5 types of LED drivers in the Infineon portfolio for automotive (Litix Automotive LED drivers).
1. Litix Linear, Basic, Basic + are linear current source LED drivers, used for tail/stop light, indicator lights etc.
2. Litix Power, Power Flex are DC DC converters with constant current output used for comparatively high power LED drivers, typically used in headlights, DRL etc.
More information on these can be found in the given link : https://www.infineon.com/cms/en/product/power/lighting-ics/litix-automotive-led-driver-ic/
AliAsgar
AliAsgar
Hi Virali,
AliAsgar
Virali_Chhag
Thank you for giving me a reply.
Kindly share price quotation, Lead time, and EOL states of the below parts.
  1. TLD2131
  2. TLD2132
  3. TLD2141
Virali Chhag
