- Email to a Friend
Dears:
When I installed DC-DC Designer,Design tool for DC-DC control ICs, an error is always showing when start running the software,and same for other computers,would you please help and advise? Thank you.
LITIX Automotive LED Driver IC
- Email to a Friend
Can you try uninstalling infineon Developer Center Launcher, DC-DC Designer and the install it back in your PC and see if the issue still exists?
Login in the developer center launcher before installing DC DC Designer from it.
AliAsgar
- Email to a Friend
Is there a launcher.conf file in the location mentioned in the error message? If yes, could you please share the .conf file with us.
AliAsgar
- Email to a Friend
Hi
launcher.conf file is missing, now we have one computer installed the tool successfully,then copy this file to failed one,it comes with a new problem.
file contents as below
"launcherPort": "60000",
"privacyPolicySentInterval": "24h",
"retrySentPrivacyPolicyDataInterval": "5m",
"allowedZipFileSize": "102400"
- Email to a Friend
Could you let me know if the latest Infineon Developer Center Launcher 2022 is installed on your PC?
Is the DC-DC designer tool working fine with the PC from where launcher.conf file was taken?
AliAsgar
- Email to a Friend
Infineon Developer Center Launcher 2022 is installed,for PC running the tool normally it 's working fine even i deleted launcher.conf file,it will re-generate again;for PC cannot run the tool,it shows the error as above.
- Email to a Friend
AliAsgar
