j_oehmen
Moderator 10 replies posted 5 replies posted 10 questions asked
Yes, LITIX Power products can be used when the power lines are being switched. Please consider that the enable pin EN / PWMI receives the correct PWM signal - and not a distorted signal after the input filter. See this application note for more details and take a look at the LITIX Power page..
