libusb Error when Programming Using openOCD CLI or ModusToolbox – KBA231563
- Mark as Read
- Printer Friendly Page
Author: VitaS_81 Version: **
Translation - Japanese: openOCDまたはModusToolbox使用しプログラミングしている場合のlibusbエラー – KBA231563 - Community Translated (JA)
Problem: Programming a PSoC® 4 or PSoC 6 MCU device with MiniProg4 or KitProg3 fails. An ‘unable to get list of LibUSB devices’ error appears in ModusToolbox® 2.2 or the openOCD 4.1 CLI log window.
Background: This issue happens when there is an unknown USB device available in Device Manager on Windows OS.
This issue is caused by a libusb bug tracked in the libusb GitHUB repository.
Solution: Try to reinstall the proper driver for the unknown device. If it does not help, remove the unknown USB device in Device Manager. When the libusb issue is addressed and a newer libusb is integrated with Cypress tools, this problem will go away.
