enCoRe II emulation
12:00 AM
- Mark as Read
- Printer Friendly Page
Dec 19, 2008
12:00 AM
Question: Does the CY3655 enCoRe II Development Kit support emulation when an external clock source is used for the enCoRe II's CPU clock?
Answer:
Emulation is not supported when using an external clock source for the enCoRe II's CPU clock. Designs which need external clock inputs are advised to use the internal clock for emulation, then switch to the external clock for final testing.
Rate this article:
Contributors
This widget could not be displayed.Anonymous
