emWin Middleware Include Path Issue - KBA228006
ChaitanyaV_61
50 questions asked 25 likes received 25 sign-ins
Author: OleksandrP_61           Version: **
Translation - Japanese: emWin ミドルウェアのインクルードパス問題 - KBA228006 - Community Translated (JA)
Context:
emWin middleware in ModusToolbox™ IDE 1.0 and 1.1.
Issue:
emWin middleware ignores configurations made in the configuration header files located in the Source/emWin_config folder (LCDConf.h and LCDConf_CompactColor_16.h).
Cause:
This issue is caused by an error in the emWin build system integration files - emWin_config folder is not added to the “include paths” list when emWin middleware is enabled in the ModusToolbox Middleware Selector.
Workaround:
You can fix the issue by adding the emWin_config folder to the “include paths” list in ModusToolbox.
To do this:
1. Select your project and then click the “Project Build Settings” link in the Quick Panel.
2. Go to C/C++ Build -> Settings
3. In the Configuration selector, select [All configurations] option.
4. In the Tool Settings tab, select GNU ARM Cross C Compiler -> Includes
5. In the Include paths list, press Add… button and enter the following path:
  "${workspace_loc:/<XXX>_mainapp}/Source/emWin_config"
      where XXX is the name of your project.
         Note
Make sure that the newly added include path is located immediately after the
     "${workspace_loc:/<XXX>_mainapp}/Source" line.
6. Press the Apply and Close button to save changes.
Contributors
