XOUT Pin of EZ-USB® HX2VL – KBA92404
Version: **
Question: When you are using an external clock, can you use the XOUT pin of an HX2VL to drive the XIN pin of another HX2VL?
Answer:
Yes. When you are using an external clock, you can use the XOUT pin of an HX2VL to drive the XIN pin of another HX2VL.
Contributors
